Ir para o conteúdo principal
Rowenta Focus Heating Element and Soleplate Replacement
O que você precisa
  1. Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: passo 1, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: passo 1, imagem 2 %32
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
  2. Rowenta Focus Heating Element and Soleplate Replacement: passo 2, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 2, imagem 2 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 2, imagem 3 %32
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
  3. Rowenta Focus Heating Element and Soleplate Replacement: passo 3, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 3, imagem 2 %32
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
  4. Rowenta Focus Heating Element and Soleplate Replacement: passo 4, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 4, imagem 2 %32
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
  5. Rowenta Focus Heating Element and Soleplate Replacement: passo 5, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 5, imagem 2 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 5, imagem 3 %32
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
  6. Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: passo 6, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: passo 6, imagem 2 %32 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: passo 6, imagem 3 %32
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
  7. Rowenta Focus Heating Element and Soleplate Replacement: passo 7, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 7, imagem 2 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 7, imagem 3 %32
    • Replace with an identical part by inserting it into the space.
  8. Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: passo 8, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: passo 8, imagem 2 %32
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
  9. Rowenta Focus Heating Element and Soleplate Replacement: passo 9, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 9, imagem 2 %32
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
  10. Rowenta Focus Heating Element and Soleplate Replacement: passo 10, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 10, imagem 2 %32
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
  11. Rowenta Focus Heating Element and Soleplate Replacement: passo 11, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 11, imagem 2 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 11, imagem 3 %32
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
  12. Rowenta Focus Heating Element and Soleplate Replacement: passo 12, imagem 1 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 12, imagem 2 %32 Rowenta Focus Heating Element and Soleplate Replacement: passo 12, imagem 3 %32
    • Lift the iron up using the handle to completely detach the soleplate.
Conclusão
3 outras pessoas executaram este guia.
Bella Navarro
Membro desde: 09/03/21
426 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 25
Últimos 30 dias: 102
Duração total: 3,590
