Ir para o conteúdo principal
Rotary Multi Selector Wheel Removal
O que você precisa
  1. Rotary Multi Selector Wheel Removal, Back Cover Removal: passo 1, imagem 1 %32 Rotary Multi Selector Wheel Removal, Back Cover Removal: passo 1, imagem 2 %32 Rotary Multi Selector Wheel Removal, Back Cover Removal: passo 1, imagem 3 %32
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  2. Rotary Multi Selector Wheel Removal: passo 2, imagem 1 %32
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  3. Rotary Multi Selector Wheel Removal, Detaching Ribbon: passo 3, imagem 1 %32 Rotary Multi Selector Wheel Removal, Detaching Ribbon: passo 3, imagem 2 %32
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  4. Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: passo 4, imagem 1 %32 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: passo 4, imagem 2 %32 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: passo 4, imagem 3 %32
    • Lift up the metal cover and its button slowly using the tweezers.
Conclusão
Andrew Lau
Membro desde: 04/18/13
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 8-56, Johann Spring 2013 Membro de Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 500
