Ir para o conteúdo principal
Rosewill NEON M62 Side Buttons Replacement
O que você precisa
  1. Rosewill NEON M62 Side Buttons Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Side Buttons Replacement: passo 2, imagem 1 %32
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Side Buttons Replacement: passo 3, imagem 1 %32 Rosewill NEON M62 Side Buttons Replacement: passo 3, imagem 2 %32
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Side Buttons Replacement, Top Cover: passo 4, imagem 1 %32 Rosewill NEON M62 Side Buttons Replacement, Top Cover: passo 4, imagem 2 %32
    • Hold the top half of the mouse with your non-dominant hand.
    • With your dominant hand, push an opening tool into the gaps in the panel.
    • Pry the panel off.
  5. Rosewill NEON M62 Side Buttons Replacement, Side Buttons: passo 5, imagem 1 %32
    • Using the opening tool, take the mouse 1 and mouse 2 buttons off the top of the mouse.
  6. Rosewill NEON M62 Side Buttons Replacement: passo 6, imagem 1 %32
    • Remove the mouse 1 and mouse 2 buttons.
  7. Rosewill NEON M62 Side Buttons Replacement: passo 7, imagem 1 %32
    • Place the mouse on its back.
  8. Rosewill NEON M62 Side Buttons Replacement: passo 8, imagem 1 %32
    • Move around the mouse piece with an opening tool, and loosen up the piece.
  9. Rosewill NEON M62 Side Buttons Replacement: passo 9, imagem 1 %32
    • Grab the mouse piece and take it out.
  10. Rosewill NEON M62 Side Buttons Replacement: passo 10, imagem 1 %32
    • You're now ready to replace the side buttons.
Conclusão
Sean Turk
Membro desde: 03/16/23
217 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 Membro de UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 78
