Introdução
This guide explains how to replace the mouse wheel on the Rosewill NEON M62 mouse. This should be replaced if the mouse wheel is visually broken or the wheel does not scroll through pages on your computer.
O que você precisa
Place the mouse so the bottom is facing upwards.
Remove the plastic skates.
Remove the two 5 mm screws with a Phillips #00 screwdriver.
Use the opening tool to push the scroll wheel RGB board up and to the right until it disconnects.
Remove the four 5 mm screws from the motherboard using a Phillips #00 screwdriver.
Remove the board from the bottom of the mouse.
