Ir para o conteúdo principal
Rosewill NEON M62 Cable Replacement
O que você precisa
  1. Rosewill NEON M62 Cable Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Cable Replacement: passo 2, imagem 1 %32
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Cable Replacement: passo 3, imagem 1 %32 Rosewill NEON M62 Cable Replacement: passo 3, imagem 2 %32
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Cable Replacement, Cable: passo 4, imagem 1 %32 Rosewill NEON M62 Cable Replacement, Cable: passo 4, imagem 2 %32
    • Gently pull the cable toward yourself and around the right side, being careful not to damage the wires.
  5. Rosewill NEON M62 Cable Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Carefully, using your fingers or tweezers, pull the white connecter up.
    • Do not pull by the wires.
Conclusão
Uma outra pessoa concluiu este guia.
Julian Abraham
Membro desde: 03/21/23
414 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 Membro de UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 78
