Ir para o conteúdo principal
Roland TR-505 Switch-board Replacement
  1. Roland TR-505 Switch-board Replacement, Removing the dials: passo 1, imagem 1 %32 Roland TR-505 Switch-board Replacement, Removing the dials: passo 1, imagem 2 %32 Roland TR-505 Switch-board Replacement, Removing the dials: passo 1, imagem 3 %32
    • With the dials in front of you carefully pull them up and away from the hide and shaft
  2. Roland TR-505 Switch-board Replacement, Removing the bottom screws: passo 2, imagem 1 %32
    • Remove these Philips PH1 screw
    • Not all screws are the same,make sure to keep them organised:-)
  3. Roland TR-505 Switch-board Replacement, Opening the device: passo 3, imagem 1 %32 Roland TR-505 Switch-board Replacement, Opening the device: passo 3, imagem 2 %32
    • Carefully separate the 2 half’s
    • If it’s not coming apart you may need a plastic pry tool to assist you
    • Once separated:with the ports facing you open the device like a book with the top panel lifted up slightly,make sure to open it to the right
  4. Roland TR-505 Switch-board Replacement, Unplugging the connectors: passo 4, imagem 1 %32
    • Carefully unplug the connectors from their sockets by pulling on the tabs that stick out from the cable
    • Do not pull on the cable itself as you risk pulling the cables out of the connector
  5. Roland TR-505 Switch-board Replacement, Disassembling the top half: passo 5, imagem 1 %32
    • with the connectors disconnected you can lift the top half away.
    • to take the switchboard off take out these PH 1 Philips screws
    • Thumbs up to Roland for adding arrows to where the screws are on the switch-board:-)
  6. Roland TR-505 Switch-board Replacement, Removing the Switch-board: passo 6, imagem 1 %32
    • Carefully lift the switch-board out
Conclusão
Uma outra pessoa concluiu este guia.
HelloMacOS
Membro desde: 01/24/22
26.654 Reputação
Autoria de 11 guias
Equipe
Repair is War on Entropy Membro de Repair is War on Entropy
Community
29 Membros
Autoria de 1.759 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 139
