Ir para o conteúdo principal
Roku XD 2050X Motherboard Replacement
O que você precisa
  1. Roku XD 2050X Motherboard Replacement, Case: passo 1, imagem 1 %32 Roku XD 2050X Motherboard Replacement, Case: passo 1, imagem 2 %32 Roku XD 2050X Motherboard Replacement, Case: passo 1, imagem 3 %32
    • Ensure the Roku XDis unplugged.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Turn the device upside down.
    • Remove the two rubber pads using a plastic spudger.
  2. Roku XD 2050X Motherboard Replacement: passo 2, imagem 1 %32 Roku XD 2050X Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the two Phillips #1 9mm pan-head screws.
  3. Roku XD 2050X Motherboard Replacement: passo 3, imagem 1 %32 Roku XD 2050X Motherboard Replacement: passo 3, imagem 2 %32 Roku XD 2050X Motherboard Replacement: passo 3, imagem 3 %32
    • Insert spudger between upper and lower frame underneath the port access.
    • Guide spudger around to loosen upper and lower frame to pry frame apart.
    • Gently remove upper frame.
  4. Roku XD 2050X Motherboard Replacement: passo 4, imagem 1 %32 Roku XD 2050X Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the two Phillips #1 8mm pan-head screws.
  5. Roku XD 2050X Motherboard Replacement: passo 5, imagem 1 %32
    • On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • Lift the motherboard out of the lower frame.
  6. Roku XD 2050X Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Replace the faulty motherboard with the new motherboard.
    • Be sure to dispose of the faulty motherboard properly. Recycle if possible!
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 4,935
