Ir para o conteúdo principal
Roku Streaming Stick Macro Button Contacts Replacement
O que você precisa
  1. Roku Streaming Stick Macro Button Contacts Replacement, Macro Button Contacts: passo 1, imagem 1 %32
    • Place the remote so that the battery cover is facing upwards.
  2. Roku Streaming Stick Macro Button Contacts Replacement: passo 2, imagem 1 %32
    • Remove the battery cover to expose the battery compartment.
  3. Roku Streaming Stick Macro Button Contacts Replacement: passo 3, imagem 1 %32
    • Remove batteries.
  4. Roku Streaming Stick Macro Button Contacts Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 1.5 mm wide screw.
  5. Roku Streaming Stick Macro Button Contacts Replacement: passo 5, imagem 1 %32 Roku Streaming Stick Macro Button Contacts Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to gently pry apart the plastic enclosure. Make sure you create a large enough gap before you attempt to separate the two pieces.
  6. Roku Streaming Stick Macro Button Contacts Replacement: passo 6, imagem 1 %32
    • Gently remove the circuit board or motherboard.
  7. Roku Streaming Stick Macro Button Contacts Replacement: passo 7, imagem 1 %32
    • First, gently remove the three plastic sheets. Then, remove the button panels from the remote control.
    • Repair the contact sheet as noted on the Button Contact Repair Kit listed above. Otherwise replace with new conductive button contacts.
Conclusão
Feliciano Bandazi
Membro desde: 04/07/18
145 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G2, Wilson Spring 2018 Membro de IUPUI, Team S2-G2, Wilson Spring 2018
IUPUI-WILSON-S18S2G2
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 30
Duração total: 3,354
