Ir para o conteúdo principal
Roku 3 Remote Control Motherboard Replacement
O que você precisa
  1. Roku 3 Remote Control Motherboard Replacement, Remote Control Battery: passo 1, imagem 1 %32
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
  2. Roku 3 Remote Control Motherboard Replacement: passo 2, imagem 1 %32 Roku 3 Remote Control Motherboard Replacement: passo 2, imagem 2 %32
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
  3. Roku 3 Remote Control Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
  4. Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: passo 4, imagem 1 %32 Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: passo 4, imagem 2 %32
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
  5. Roku 3 Remote Control Motherboard Replacement: passo 5, imagem 1 %32 Roku 3 Remote Control Motherboard Replacement: passo 5, imagem 2 %32
    • Gently pry open the remote using the plastic opening tool.
  6. Roku 3 Remote Control Motherboard Replacement: passo 6, imagem 1 %32 Roku 3 Remote Control Motherboard Replacement: passo 6, imagem 2 %32
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
  7. Roku 3 Remote Control Motherboard Replacement: passo 7, imagem 1 %32
    • Set aside the half of the remote with the buttons.
    • Take the the other half of the remote with one hand and remove the motherboard with your thumb and forefinger of the other hand.
Conclusão
3 outras pessoas executaram este guia.
Isobelle Espiritu
Membro desde: 10/06/16
591 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 15-2, Livingston Fall 2016 Membro de Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
Membros da 3
Autoria de 6 guias
4 comentários
Thanks for the tutorial. Any idea where I can buy the motherboard for the Roku 3 remote?
Bret Dennis - Responder
Where can I buy a Roku 3 remote motherboard replacement?
A. J. Sitarsky - Responder
Hi, wondered if you had any luck locating a motherboard for the Roku 3? Thanks!
Paul Cacioppo -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 29
Duração total: 5,057
