Ir para o conteúdo principal
Roku 2 Roku 2 Motherboard Replacement
O que você precisa
  1. Roku 2 Roku 2 Motherboard Replacement, Roku 2 Motherboard: passo 1, imagem 1 %32
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • It may take multiple heats, left for a minute at a time, to properly loosen the glue.
  2. Roku 2 Roku 2 Motherboard Replacement: passo 2, imagem 1 %32
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2 Roku 2 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the four Phillips #000 screws from the bottom of the case.
  4. Roku 2 Roku 2 Motherboard Replacement: passo 4, imagem 1 %32
    • Gently remove the under side of the device.
  5. Roku 2 Roku 2 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2 Roku 2 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2 Roku 2 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the board from the plastic enclosure.
Conclusão
Eric Rawls
Membro desde: 08/24/15
360 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-5, Sullivan Fall 2015 Membro de USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,160
