Ir para o conteúdo principal
Roconia Q6 Lamp Replacement
O que você precisa
  1. Roconia Q6 Lamp Replacement, Top Cover: passo 1, imagem 1 %32 Roconia Q6 Lamp Replacement, Top Cover: passo 1, imagem 2 %32
    • Flip your device upside down so that the interface is facing downwards.
  2. Roconia Q6 Lamp Replacement: passo 2, imagem 1 %32 Roconia Q6 Lamp Replacement: passo 2, imagem 2 %32 Roconia Q6 Lamp Replacement: passo 2, imagem 3 %32
    • The device is supported by rubber pieces located at the bottom extremities.
    • There are screws beneath the rubber pieces that can be removed. Remove all four 1.1 mm Phillips #1 screws by using the Phillips #0 screwdriver.
  3. Roconia Q6 Lamp Replacement: passo 3, imagem 1 %32 Roconia Q6 Lamp Replacement: passo 3, imagem 2 %32 Roconia Q6 Lamp Replacement: passo 3, imagem 3 %32
    • Turn device over again and pry open the device to remove the cover.
  4. Roconia Q6 Lamp Replacement: passo 4, imagem 1 %32 Roconia Q6 Lamp Replacement: passo 4, imagem 2 %32 Roconia Q6 Lamp Replacement: passo 4, imagem 3 %32
    • Pull out the cable that is connected to the top cover to fully separate.
  5. Roconia Q6 Lamp Replacement, Lamp: passo 5, imagem 1 %32 Roconia Q6 Lamp Replacement, Lamp: passo 5, imagem 2 %32 Roconia Q6 Lamp Replacement, Lamp: passo 5, imagem 3 %32
    • We need to locate the screws which are holding down another plastic covering.
    • Use a Phillips #1 screwdriver to remove each of the highlighted 8.8 mm screws.
  6. Roconia Q6 Lamp Replacement: passo 6, imagem 1 %32 Roconia Q6 Lamp Replacement: passo 6, imagem 2 %32 Roconia Q6 Lamp Replacement: passo 6, imagem 3 %32
    • There is another screw holding down the plastic covering and it is located on the motherboard. With the same screwdriver, remove that screw.
    • Now carefully pull out the highlighted cables that is connecting to the motherboard that will prevent you from completely removing the plastic cover.
  7. Roconia Q6 Lamp Replacement: passo 7, imagem 1 %32 Roconia Q6 Lamp Replacement: passo 7, imagem 2 %32 Roconia Q6 Lamp Replacement: passo 7, imagem 3 %32
    • From here you will be able to safely remove the plastic covering and expose a second layer of parts.
  8. Roconia Q6 Lamp Replacement: passo 8, imagem 1 %32 Roconia Q6 Lamp Replacement: passo 8, imagem 2 %32 Roconia Q6 Lamp Replacement: passo 8, imagem 3 %32
    • We can now locate the lamp which is being held in place by the mirror part.
    • Carefully remove the mirror, without putting any smudges on the inside from our finger.
    • From there you will be able to remove the lamp and replace.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 57
Duração total: 92
