Introdução
This is a step-by-step guide on how to locate and replace the lamp of the Roconia Q6 projector. The lamp is located in the second layer of the projector, so it requires a bit more work and carefulness to reach and replace.
O que você precisa
We need to locate the screws which are holding down another plastic covering.
Use a Phillips #1 screwdriver to remove each of the highlighted 8.8 mm screws.
There is another screw holding down the plastic covering and it is located on the motherboard. With the same screwdriver, remove that screw.
Now carefully pull out the highlighted cables that is connecting to the motherboard that will prevent you from completely removing the plastic cover.
