Ir para o conteúdo principal
Rocketfish RF-WSP313 Speaker Replacement
O que você precisa
  1. Rocketfish RF-WSP313 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Using the metal spudger, remove the outer cap from the top of the device.
  2. Rocketfish RF-WSP313 Speaker Replacement: passo 2, imagem 1 %32
    • Using a Phillips # 1 screwdriver, remove the four 1.1 cm flathead screws attaching the metal ring to the top of the device.
  3. Rocketfish RF-WSP313 Speaker Replacement: passo 3, imagem 1 %32
    • Remove the ring and set aside.
  4. Rocketfish RF-WSP313 Speaker Replacement: passo 4, imagem 1 %32
    • Using the metal spudger, remove the cap from the bottom of the device.
  5. Rocketfish RF-WSP313 Speaker Replacement: passo 5, imagem 1 %32
    • Using a Phillips # 1 screwdriver, remove the four 1.1 sm screws attaching the metal ring to the bottom of the device.
  6. Rocketfish RF-WSP313 Speaker Replacement: passo 6, imagem 1 %32
  7. Rocketfish RF-WSP313 Speaker Replacement: passo 7, imagem 1 %32
    • Using a Phillips # 1 screwdriver, remove the four 1 cm screws from the outside panel. You will do this for each panel; it does not matter which side you start with.
  8. Rocketfish RF-WSP313 Speaker Replacement: passo 8, imagem 1 %32
    • Using the metal spudger, pry off the side panel. Repeat this step on the other side panel.
  9. Rocketfish RF-WSP313 Speaker Replacement: passo 9, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the four 1.1 cm flathead screws from the side of the device. Repeat this step on the other side of the device.
  10. Rocketfish RF-WSP313 Speaker Replacement: passo 10, imagem 1 %32 Rocketfish RF-WSP313 Speaker Replacement: passo 10, imagem 2 %32
    • Using the metal spudger, open the device.
  11. Rocketfish RF-WSP313 Speaker Replacement: passo 11, imagem 1 %32 Rocketfish RF-WSP313 Speaker Replacement: passo 11, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using your fingers (or a pair of tweezers), disconnect the speaker cord from its socket.
  12. Rocketfish RF-WSP313 Speaker Replacement: passo 12, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the four 1.2 cm pan head screws surrounding the speaker.
  13. Rocketfish RF-WSP313 Speaker Replacement: passo 13, imagem 1 %32
    • Remove the speaker from the device.
Conclusão
Kara Falknor
Membro desde: 01/25/17
101 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 599
