Ir para o conteúdo principal
Roborock Q5 Max Plus Bottom Shell Replacement
O que você precisa
  1. Roborock Q5 Max Plus Bottom Shell Replacement, Side Brush: passo 1, imagem 1 %32 Roborock Q5 Max Plus Bottom Shell Replacement, Side Brush: passo 1, imagem 2 %32
    • Carefully flip the Roborock upside down on a soft surface (e.g., towel) to avoid scratches.
    • Turn off the vacuum using the main switch underneath.
  2. Roborock Q5 Max Plus Bottom Shell Replacement: passo 2, imagem 1 %32 Roborock Q5 Max Plus Bottom Shell Replacement: passo 2, imagem 2 %32 Roborock Q5 Max Plus Bottom Shell Replacement: passo 2, imagem 3 %32
    • Hold down the side brush with one hand to prevent it from moving.
    • Use a Phillips #1 screwdriver to remove the single screw securing the side brush.
    • Remove it from the base.
  3. Roborock Q5 Max Plus Bottom Shell Replacement, Bottom Panel: passo 3, imagem 1 %32 Roborock Q5 Max Plus Bottom Shell Replacement, Bottom Panel: passo 3, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the eight 14 mm screws that secure the bottom shell.
  4. Roborock Q5 Max Plus Bottom Shell Replacement: passo 4, imagem 1 %32
    • Gently lift the the bottom shell up and off.
    • If you encounter resistance, double-check for any hidden screws that may have been overlooked.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 335
