Ir para o conteúdo principal
Rival Mini Chopper MC-67BL Turning Gears Replacement
O que você precisa
  1. Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: passo 1, imagem 1 %32 Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: passo 1, imagem 2 %32
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 2, imagem 1 %32
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 3, imagem 1 %32
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 4, imagem 1 %32
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 5, imagem 1 %32 Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 5, imagem 2 %32
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 6, imagem 1 %32
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 7, imagem 1 %32
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 8, imagem 1 %32 Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 8, imagem 2 %32 Rival Mini Chopper MC-67BL Turning Gears Replacement: passo 8, imagem 3 %32
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
Conclusão
Uma outra pessoa concluiu este guia.
Roxanne
Membro desde: 10/17/13
522 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 4-29, Amido Fall 2013 Membro de Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 839
