Introdução
This guide will help you remove the motor and requires the uses of a soldering iron. Check out this soldering guide for help if you don't know how to solder.
O que você precisa
Twist the plastic lid counterclockwise to unlock it.
Lift the lid to remove it from the container.
Use a soldering kit to remove solder from the circuit board for the red wire.
Follow this soldering guide if you need extra help!
3 outras pessoas executaram este guia.
