Pular para o conteúdo principal
Perigo
Potencialmente perigoso
Se este procedimento não for seguido corretamente, podem ocorrer ferimentos. Use cautela e siga todos os avisos.
Perigo
Introdução
Many water heaters / kettles use systems from Strix. The one I got is sold by German company Ritter.
Be extremely careful when operating the PCB out of the box as it may contain voltages of up to 320VDC !
Ferramentas
Peças
  1. Using Torx screwdriver, open kettle base and remove PCB One can see the five contact rings. From inside they are: Live, Sensor +, Sensor -, Neutral, Ground
    • Using Torx screwdriver, open kettle base and remove PCB
    • One can see the five contact rings. From inside they are: Live, Sensor +, Sensor -, Neutral, Ground
  2. The PCB is not conformally coated, so water splashing around the base can potentially enter and cause damage.
    • The PCB is not conformally coated, so water splashing around the base can potentially enter and cause damage.
    • The design of the PCB is a bit unfortunate as the high voltage switching regulator is very close to the LDO and microcontroller.
    • Line input
    • Switching regulator
    • LDO and MCU
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Comprar agora
    iPhone X Fix Kits
    Comprar agora
  4. Red circle: Isolation gap between 320VDC and 4.4VDC is about less than 1mm
    • Red circle: Isolation gap between 320VDC and 4.4VDC is about less than 1mm
    • Red arrow: Pulsed 320V (220VAC) switching regulator
    • Blue arrow: 4.4V LDO supply voltage for MCU
  5. Using hot air, desolder the TSSOP16 microcontroller labeled "Y12"
    • Using hot air, desolder the TSSOP16 microcontroller labeled "Y12"
    • Unfortunately I was not able to source the microcontroller allone yet. But I could order the entire board for 25€ which is better than nothing. Thank you Ritter
Conclusão
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Thomas Widmaier
Membro desde: 05-03-2013
1.372 reputação
9 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
287 Membros
811 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 33
