Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Many water heaters / kettles use systems from Strix. The one I got is sold by German company Ritter.
Be extremely careful when operating the PCB out of the box as it may contain voltages of up to 320VDC!
O que você precisa
Using Torx screwdriver, open kettle base and remove PCB
One can see the five contact rings. From inside they are: Live, Sensor +, Sensor -, Neutral, Ground
The PCB is not conformally coated, so water splashing around the base can potentially enter and cause damage.
The design of the PCB is a bit unfortunate as the high voltage switching regulator is very close to the LDO and microcontroller.
Line input
Switching regulator
LDO and MCU
Red circle: Isolation gap between 320VDC and 4.4VDC is about less than 1mm
Red arrow: Pulsed 320V (220VAC) switching regulator
Blue arrow: 4.4V LDO supply voltage for MCU
Using hot air, desolder the TSSOP16 microcontroller labeled "Y12"
Unfortunately I was not able to source the microcontroller allone yet. But I could order the entire board for 25€ which is better than nothing. Thank you Ritter
