Ir para o conteúdo principal
Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement
O que você precisa
  1. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Open kettle base: passo 1, imagem 1 %32 Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Open kettle base: passo 1, imagem 2 %32
    • Before you begin, be sure to unplug the kettle base.
    • Using Torx screwdriver, open kettle base and remove PCB
    • One can see the five contact rings. From inside they are: Live, Sensor +, Sensor -, Neutral, Ground
  2. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, High voltage gap potential problem: passo 2, imagem 1 %32
    • The PCB is not conformally coated, so water splashing around the base can potentially enter and cause damage.
    • The design of the PCB is a bit unfortunate as the high voltage switching regulator is very close to the LDO and microcontroller.
    • Line input
    • Switching regulator
    • LDO and MCU
  3. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, High voltage gap problem (2): passo 3, imagem 1 %32
    • Red circle: Isolation gap between 320VDC and 4.4VDC is about less than 1mm
    • Red arrow: Pulsed 320V (220VAC) switching regulator
    • Blue arrow: 4.4V LDO supply voltage for MCU
  4. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Microcontroller replacement: passo 4, imagem 1 %32
    • Using hot air, desolder the TSSOP16 microcontroller labeled "Y12"
    • Unfortunately I was not able to source the microcontroller allone yet. But I could order the entire board for 25€ which is better than nothing. Thank you Ritter
Conclusão
Thomas Widmaier
Membro desde: 03/05/13
2.039 Reputação
Autoria de 10 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.527 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 358
