Ir para o conteúdo principal
Ring Video Doorbell Housing Replacement
O que você precisa
  1. Ring Video Doorbell Housing Replacement, Housing: passo 1, imagem 1 %32 Ring Video Doorbell Housing Replacement, Housing: passo 1, imagem 2 %32 Ring Video Doorbell Housing Replacement, Housing: passo 1, imagem 3 %32
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Housing Replacement: passo 2, imagem 1 %32 Ring Video Doorbell Housing Replacement: passo 2, imagem 2 %32 Ring Video Doorbell Housing Replacement: passo 2, imagem 3 %32
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell Housing Replacement: passo 3, imagem 1 %32 Ring Video Doorbell Housing Replacement: passo 3, imagem 2 %32 Ring Video Doorbell Housing Replacement: passo 3, imagem 3 %32
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell Housing Replacement: passo 4, imagem 1 %32
    • Remove the plastic film using the Plastic Tool Opener.
Conclusão
3 outras pessoas executaram este guia.
Abdulrahman
Membro desde: 02/20/18
685 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membro de USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
Membros da 3
Autoria de 10 guias
Um comentário
Hey, do you know if Ring will provide you with replacement front housing? My casing has been damaged by an attempted theft :(
Charlie Adamson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 34
Duração total: 3,083
