Ir para o conteúdo principal
Ring Video Doorbell Battery Replacement
O que você precisa
  1. Ring Video Doorbell Battery Replacement, Battery: passo 1, imagem 1 %32 Ring Video Doorbell Battery Replacement, Battery: passo 1, imagem 2 %32 Ring Video Doorbell Battery Replacement, Battery: passo 1, imagem 3 %32
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Battery Replacement: passo 2, imagem 1 %32 Ring Video Doorbell Battery Replacement: passo 2, imagem 2 %32 Ring Video Doorbell Battery Replacement: passo 2, imagem 3 %32
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
Conclusão
Abdulrahman
Membro desde: 02/20/18
685 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membro de USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
Membros da 3
Autoria de 10 guias
4 comentários
Where do I get a replacement battery?
William Price - Responder
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - Responder
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - Responder
can it be sent to the manufacturers for a replacement
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 82
Últimos 30 dias: 332
Duração total: 8,606
