Ir para o conteúdo principal
Ring Video Doorbell Battery Replacement
O que você precisa
  1. Ring Video Doorbell Battery Replacement, Battery: passo 1, imagem 1 %32 Ring Video Doorbell Battery Replacement, Battery: passo 1, imagem 2 %32 Ring Video Doorbell Battery Replacement, Battery: passo 1, imagem 3 %32
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Ring Video Doorbell Battery Replacement: passo 2, imagem 1 %32 Ring Video Doorbell Battery Replacement: passo 2, imagem 2 %32 Ring Video Doorbell Battery Replacement: passo 2, imagem 3 %32
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Abdulrahman
Membro desde: 02/20/18
709 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membro de USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Membros
Autoria de 10 guias
7Comentários do guia
Where do I get a replacement battery?
William Price - Responder Compartilhar
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - Responder Compartilhar
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - Responder Compartilhar
can it be sent to the manufacturers for a replacement
similar to David, I pulled off the battery connector and reattached it, then sealed with some rubber cement. Unit immediately went back online.
Daniel Wise - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 104
Últimos 30 dias: 454
Ao todo: 19,509
