Ir para o conteúdo principal
Ring Video Doorbell Speakers Replacement
O que você precisa
  1. Ring Video Doorbell  Speakers Replacement, Motherboard: passo 1, imagem 1 %32 Ring Video Doorbell  Speakers Replacement, Motherboard: passo 1, imagem 2 %32 Ring Video Doorbell  Speakers Replacement, Motherboard: passo 1, imagem 3 %32
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Ring Video Doorbell  Speakers Replacement: passo 2, imagem 1 %32 Ring Video Doorbell  Speakers Replacement: passo 2, imagem 2 %32 Ring Video Doorbell  Speakers Replacement: passo 2, imagem 3 %32
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
    Pergunte ao FixBot
    Comentar
  3. Ring Video Doorbell  Speakers Replacement: passo 3, imagem 1 %32 Ring Video Doorbell  Speakers Replacement: passo 3, imagem 2 %32 Ring Video Doorbell  Speakers Replacement: passo 3, imagem 3 %32
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
    Pergunte ao FixBot
    Comentar
  4. Ring Video Doorbell  Speakers Replacement: passo 4, imagem 1 %32 Ring Video Doorbell  Speakers Replacement: passo 4, imagem 2 %32
    • Detach the upper part of the motherboard from the bottom, using your hands.
    Pergunte ao FixBot
    Comentar
  5. Ring Video Doorbell  Speakers Replacement, Speakers: passo 5, imagem 1 %32
    • Speakers are two small rectangles located above the button of the doorbell.
    Pergunte ao FixBot
    Comentar
  6. Ring Video Doorbell  Speakers Replacement: passo 6, imagem 1 %32
    • To remove the speakers pry each one out carefully with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Oscar Pascual-Diego
Membro desde: 02/20/18
121 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membro de USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Membros
Autoria de 10 guias
1Comentário do guia
Where does one get replacement speakers for the 88RG000FC100 ring doorbell?
Jeffrey Lang - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 78
Ao todo: 5,991
