Ir para o conteúdo principal
Ring Stick Up Cam Microphone Replacement
O que você precisa
  1. Ring Stick Up Cam Microphone Replacement, Battery: passo 1, imagem 1 %32
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Microphone Replacement: passo 2, imagem 1 %32
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Microphone Replacement: passo 3, imagem 1 %32
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Microphone Replacement: passo 4, imagem 1 %32
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Microphone Replacement: passo 5, imagem 1 %32
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Microphone Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  7. Ring Stick Up Cam Microphone Replacement, Camera: passo 7, imagem 1 %32
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
  8. Ring Stick Up Cam Microphone Replacement: passo 8, imagem 1 %32
    • Disconnect the ribbon connector shown in the photo.
  9. Ring Stick Up Cam Microphone Replacement: passo 9, imagem 1 %32
    • Remove the motherboard from the device by hand.
  10. Ring Stick Up Cam Microphone Replacement: passo 10, imagem 1 %32
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
  11. Ring Stick Up Cam Microphone Replacement: passo 11, imagem 1 %32
    • Remove the three plastic spacers shown in the photo by hand.
  12. Ring Stick Up Cam Microphone Replacement: passo 12, imagem 1 %32
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
  13. Ring Stick Up Cam Microphone Replacement: passo 13, imagem 1 %32
    • Lift the camera board out of the housing using your hand.
  14. Ring Stick Up Cam Microphone Replacement, Microphone: passo 14, imagem 1 %32
    • Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
  15. Ring Stick Up Cam Microphone Replacement: passo 15, imagem 1 %32
    • Use a plastic opening tool to carefully pry the microphone from the housing.
  16. Ring Stick Up Cam Microphone Replacement: passo 16, imagem 1 %32
    • Use your hands to remove the daughterboard containing the microphone from the housing.
Conclusão
Chunyue Liu
Membro desde: 02/06/19
273 Reputação
Autoria de 2 guias
Equipe
UC Davis, Team S18-G3, Lore Winter 2019 Membro de UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 2,880
