Ir para o conteúdo principal
Ring Stick Up Cam Battery Speaker Replacement
O que você precisa
  1. Ring Stick Up Cam Battery Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Turn the camera so the lens is facing away from you, and the back is facing towards you.
    • Place one hand securely on the base and the other on the stand.
    • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
  2. Ring Stick Up Cam Battery Speaker Replacement: passo 2, imagem 1 %32
    • Gently pull down to separate the stand from the camera body.
  3. Ring Stick Up Cam Battery Speaker Replacement: passo 3, imagem 1 %32 Ring Stick Up Cam Battery Speaker Replacement: passo 3, imagem 2 %32
    • Hold the camera so the opening containing the battery is toward the ceiling.
    • Squeeze the silver lever labeled "push" and extract the battery from its slot.
  4. Ring Stick Up Cam Battery Speaker Replacement, Motherboard: passo 4, imagem 1 %32
    • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
  5. Ring Stick Up Cam Battery Speaker Replacement: passo 5, imagem 1 %32
    • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
  6. Ring Stick Up Cam Battery Speaker Replacement: passo 6, imagem 1 %32
    • Rotate the device so the base is facing upward.
    • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
    • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
  7. Ring Stick Up Cam Battery Speaker Replacement: passo 7, imagem 1 %32
    • Remove the silver latch from the base.
    • Remove the front cover.
    • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
    • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
  8. Ring Stick Up Cam Battery Speaker Replacement: passo 8, imagem 1 %32
    • Pry the inside panel open using your hands or a spudger if necessary.
  9. Ring Stick Up Cam Battery Speaker Replacement: passo 9, imagem 1 %32
    • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
  10. Ring Stick Up Cam Battery Speaker Replacement: passo 10, imagem 1 %32 Ring Stick Up Cam Battery Speaker Replacement: passo 10, imagem 2 %32
    • Lift the motherboard from the camera body with the halberd spudger.
  11. Ring Stick Up Cam Battery Speaker Replacement: passo 11, imagem 1 %32 Ring Stick Up Cam Battery Speaker Replacement: passo 11, imagem 2 %32
    • Rotate the device to its side.
    • With your fingers, carefully remove the white part of the cord clip from the beige base.
    • Repeat this for the remaining three cords connecting the motherboard to the camera body.
  12. Ring Stick Up Cam Battery Speaker Replacement: passo 12, imagem 1 %32
    • Fold the motherboard downward from the camera body, revealing a white connecting strip.
    • Using the flat end of a spudger, flick the black hinge upward.
    • Pull the white strip out of the slot.
  13. Ring Stick Up Cam Battery Speaker Replacement: passo 13, imagem 1 %32 Ring Stick Up Cam Battery Speaker Replacement: passo 13, imagem 2 %32
    • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
    • Gently remove the adhesive cover from the motherboard.
  14. Ring Stick Up Cam Battery Speaker Replacement, Camera: passo 14, imagem 1 %32
    • Orient your device so that the interior of the camera body is facing the ceiling.
  15. Ring Stick Up Cam Battery Speaker Replacement: passo 15, imagem 1 %32
    • Remove the two 6 mm screws that connect the camera to the camera body using a Phillips #00 screwdriver.
  16. Ring Stick Up Cam Battery Speaker Replacement: passo 16, imagem 1 %32
    • Grab and twist the camera counterclockwise with your thumb and index finger.
  17. Ring Stick Up Cam Battery Speaker Replacement: passo 17, imagem 1 %32 Ring Stick Up Cam Battery Speaker Replacement: passo 17, imagem 2 %32
    • Using your fingers, lift out the camera component including the camera lens and the attached wire.
  18. Ring Stick Up Cam Battery Speaker Replacement, Microphone: passo 18, imagem 1 %32
    • Remove the two 4 mm screws connecting the metal protective piece to the camera body using a Phillips #00 screwdriver.
  19. Ring Stick Up Cam Battery Speaker Replacement: passo 19, imagem 1 %32
    • Using your fingers, carefully pinch the white connector attached to the black cable, and gently pull it out of its slot on the daughterboard.
  20. Ring Stick Up Cam Battery Speaker Replacement: passo 20, imagem 1 %32
    • Rotate the camera body to a comfortable position.
    • Use the spudger to pry the metal component from the camera body.
    • The daughterboard and microphone should now be exposed.
  21. Ring Stick Up Cam Battery Speaker Replacement: passo 21, imagem 1 %32
    • Gently remove the daughterboard from the base with your hands or the spudger if necessary.
  22. Ring Stick Up Cam Battery Speaker Replacement: passo 22, imagem 1 %32 Ring Stick Up Cam Battery Speaker Replacement: passo 22, imagem 2 %32
    • Use the hook end of the halberd spudger to carefully lift the microphone from the base.
  23. Ring Stick Up Cam Battery Speaker Replacement, Speaker: passo 23, imagem 1 %32
    • Remove the two 4 mm screws from the upper black cover panel using a Phillips #00 screwdriver.
    • Remove the two 4 mm screws from the lower black cover panel using a Phillips #00 screwdriver.
  24. Ring Stick Up Cam Battery Speaker Replacement: passo 24, imagem 1 %32
    • Use the spudger to pry the rectangular black panel from the camera body.
  25. Ring Stick Up Cam Battery Speaker Replacement: passo 25, imagem 1 %32 Ring Stick Up Cam Battery Speaker Replacement: passo 25, imagem 2 %32
    • Rotate the camera body upward.
    • Use your hands or the spudger to lift the lower black panel to reveal the speaker.
Conclusão
Vanessa Hasbrouck
Membro desde: 02/24/23
339 Reputação
Autoria de 2 guias
Equipe
Marist, Team 1-1, Chaterdon Spring 2023 Membro de Marist, Team 1-1, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 125
