Ir para o conteúdo principal
Ring Spotlight Cam Battery The Mounting Bracket Replacement
O que você precisa
  1. Ring Spotlight Cam Battery The Mounting Bracket  Replacement, The Mounting Bracket: passo 1, imagem 1 %32
    • Place Mounting Bracket with lower elevation facing towards you.
  2. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the single bracket screw.
  3. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: passo 3, imagem 1 %32
    • Hold two corners from the middle of bracket and stretch outward.
  4. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: passo 4, imagem 1 %32
    • Slide bracket upwards.
Conclusão
Um comentário
I have lost the single bracket screw. Where can I get a replacement?
Rick Burgess - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 2,740
