Ir para o conteúdo principal
Ring Outdoor Security Cam Infrared Sensor Replacement
O que você precisa
  1. Ring Outdoor Security Cam Infrared Sensor Replacement, Infrared Sensor: passo 1, imagem 1 %32
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
    Pergunte ao FixBot
    Comentar
  2. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 2, imagem 1 %32
    • Pry off the aluminum plate using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  3. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 3, imagem 1 %32
    • Using the same tool pry the back plate off of the device.
    Pergunte ao FixBot
    Comentar
  4. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 4, imagem 1 %32
    • Disconnect the battery power leads using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  5. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    Pergunte ao FixBot
    Comentar
  6. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 6, imagem 1 %32
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the three silver 6 mm Phillips #00 screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 7, imagem 1 %32
    • Pull the top of the motherboard up and out of the device.
    Pergunte ao FixBot
    Comentar
  8. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 8, imagem 1 %32 Ring Outdoor Security Cam Infrared Sensor Replacement: passo 8, imagem 2 %32
    • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
    • Remove the 3 plastic spacers on the device.
    Pergunte ao FixBot
    Comentar
  9. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 9, imagem 1 %32 Ring Outdoor Security Cam Infrared Sensor Replacement: passo 9, imagem 2 %32 Ring Outdoor Security Cam Infrared Sensor Replacement: passo 9, imagem 3 %32
    • Pry the motherboard out with a plastic opening tool.
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
    Pergunte ao FixBot
    Comentar
  10. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 10, imagem 1 %32
    • Using a soldering iron to disconnect the connections.
    • Remove the infrared sensor and replace as needed.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 546
