Ir para o conteúdo principal
Rimless Glasses Temple Replacement
O que você precisa
  1. Rimless Glasses Temple Replacement, Rimless Glasses Temple Replacement: passo 1, imagem 1 %32 Rimless Glasses Temple Replacement, Rimless Glasses Temple Replacement: passo 1, imagem 2 %32 Rimless Glasses Temple Replacement, Rimless Glasses Temple Replacement: passo 1, imagem 3 %32
    • Take the compression sleeves and insert them into the outer lens holes with the pins facing out.
  2. Rimless Glasses Temple Replacement: passo 2, imagem 1 %32 Rimless Glasses Temple Replacement: passo 2, imagem 2 %32
    • Using the cutting head of the glasses plier, trim the compression sleeve pins down so that only 1 mm remains sticking out the front of the glasses.
    • Take a push pin and enlarge the holes of compression sleeves by gently inserting the pin into the holes.
  3. Rimless Glasses Temple Replacement: passo 3, imagem 1 %32 Rimless Glasses Temple Replacement: passo 3, imagem 2 %32 Rimless Glasses Temple Replacement: passo 3, imagem 3 %32
    • Insert the arm of the glasses into the enlarged holes of the compression sleeves.
    • Use a silhousette to gently press the arm from the top and tighten it to the glasses.
Conclusão
2 comentários
This is very good if the frame arm just fell off of the lens, but it doesn't tell how to remove a broken frame arm from the lens—ie, how to get the compression sleeve off of the broken arm without damaging the lens.
JM MJ - Responder
for new lenses what are the hole centres for 2 pin please?
hoare - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 64
Últimos 30 dias: 287
Duração total: 9,709
