Introdução
If your Rienok S1 Mini speaker sounds muffled or no sound is playing, you will have to replace the speaker drivers.
A functional speaker will provide better sound quality for music. If you use the speakers often and the sound quality progressively sounds muffled, replace the speakers.
Make sure to power down the device before you begin.
O que você precisa
Start with the buttons panel up and facing you.
Wedge in one iFixit opening pick, and apply outward pressure to pop out one side of the grille.
Using a second pick, slide from the first pick towards the opposite end until one whole side is popped out.
Wedge an iFixit opening pick into the space between the ring and the housing.
Insert a Jimmy into the gap created.
Apply an out-and-upward pressure with the Jimmy to disconnect the plastic clips surrounding the ring.
Work the Jimmy around the ring, disconnecting the clips along the way until they are all disconnected.
Hold the device with the speakers facing up.
Remove the six 10 mm silver screws connecting the two halves of the case with a Phillips #1 screwdriver.
Insert a Jimmy into the seam between both halves.
Lightly twist the Jimmy until a small gap appears.
Work the Jimmy across the length creating and widening the gap as you go across.
With the gap across the whole length, grasp both halves and lightly pull apart.
DO NOT yank apart; the two halves are still connected by a few cords.
Remove eight 8 mm screws from the speaker drivers using a Phillips #000 screwdriver.
