Introdução
Soldering is required for some of the steps in this guide. Refer to the iFixit guide on Soldering if you need help learning how to solder. This replacement guide requires dealing with grease, make sure that you are wearing clothes that can get dirty and you are working on a surface that can get dirty.
O que você precisa
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Uma outra pessoa concluiu este guia.
