Ir para o conteúdo principal
Ridgid R86034 LED Replacement
O que você precisa
  1. Ridgid R86034 LED Replacement, Disassembling Ridgid R86034 Housing: passo 1, imagem 1 %32
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use some force; the rubber cover is securely attached to the housing.
    • Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
    • Orientation is important when putting the rubber cover on the casing.
  2. Ridgid R86034 LED Replacement: passo 2, imagem 1 %32 Ridgid R86034 LED Replacement: passo 2, imagem 2 %32
    • Remove the plastic cover with your hands.
    • There is no need to force off the plastic cover. The plastic cover should be much easier to remove than the rubber cover.
  3. Ridgid R86034 LED Replacement: passo 3, imagem 1 %32 Ridgid R86034 LED Replacement: passo 3, imagem 2 %32 Ridgid R86034 LED Replacement: passo 3, imagem 3 %32
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
  4. Ridgid R86034 LED Replacement: passo 4, imagem 1 %32 Ridgid R86034 LED Replacement: passo 4, imagem 2 %32
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
  5. Ridgid R86034 LED Replacement: passo 5, imagem 1 %32
    • Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger.
    • The housing is easier to remove if you pry from multiple sides.
  6. Ridgid R86034 LED Replacement: passo 6, imagem 1 %32 Ridgid R86034 LED Replacement: passo 6, imagem 2 %32
    • Do not remove the direction switch.
    • Pull out all electrical components from housing by hand.
    • Lift out the motor.
    • Follow the wires.
    • The components should come out of their respective slots with ease and require little force to lift out.
    • The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • Remember to precisely place all components in their correct slots with their correct orientations when reassembling.
  7. Ridgid R86034 LED Replacement, LED: passo 7, imagem 1 %32
    • Identify the LED light. The LED light is the component with clear casing and has two wires attached, located toward the bottom of the driver.
  8. Ridgid R86034 LED Replacement: passo 8, imagem 1 %32 Ridgid R86034 LED Replacement: passo 8, imagem 2 %32 Ridgid R86034 LED Replacement: passo 8, imagem 3 %32
    • Cut the pink and white wires attached to the LED at a point that is a little more than 1/4 inch from the LED.
  9. Ridgid R86034 LED Replacement: passo 9, imagem 1 %32
    • Strip the wires back about 1/4 inch on the LED.
  10. Ridgid R86034 LED Replacement: passo 10, imagem 1 %32 Ridgid R86034 LED Replacement: passo 10, imagem 2 %32
    • Strip the wires that were connected to the LED on the circuit board to approximately 1/4 inch.
  11. Ridgid R86034 LED Replacement: passo 11, imagem 1 %32
    • Solder the new LED striped wires to the wire attached to the circuit board.
    • Wrap the soldered connection with electrical tape, to ensure that the circuit isn't shorted.
Conclusão
Sean Liston
Membro desde: 04/28/15
311 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-5, Amido Spring 2015 Membro de Cal Poly, Team 15-5, Amido Spring 2015
CPSU-AMIDO-S15S15G5
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,117
