Introdução
If you blow a fuse in the impact driver you only have to open up the device and replace the broken fuse with a new one.
O que você precisa
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Identify the translucent orange fuse cartridge connected by a thick red wire and a thick white wire.
Quase terminado!
Conclusão
