Ir para o conteúdo principal
Ridgid R82005 LED Light Replacement
O que você precisa
  1. Ridgid R82005 LED Light Replacement, Housing Assembly: passo 1, imagem 1 %32
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005 LED Light Replacement: passo 2, imagem 1 %32
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005 LED Light Replacement: passo 3, imagem 1 %32 Ridgid R82005 LED Light Replacement: passo 3, imagem 2 %32
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005 LED Light Replacement: passo 4, imagem 1 %32 Ridgid R82005 LED Light Replacement: passo 4, imagem 2 %32
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005 LED Light Replacement, LED Light: passo 5, imagem 1 %32 Ridgid R82005 LED Light Replacement, LED Light: passo 5, imagem 2 %32
    • Unplug the LED connector gently.
Conclusão
Equipe
USF Tampa, Team S1-G2, Leahy Spring 2019 Membro de USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 279
