Introdução
The Ridgid R82005 speed gear switch alters the amount of power intended for specific drill-driver bits and the type of materials manipulated by operators. Forcing this tool to produce torque beyond the limits of a speed gear can cause jams that compromise the drill's versatility.
O que você precisa
Eject the battery from the drill.
Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
Remove the 2 speed gear selector by carefully lifting it out of the housing, making sure it is free from the speed switch rail.
4 outras pessoas executaram este guia.
