Ir para o conteúdo principal
Ridgid R82005 2 Speed Gear Train Replacement
O que você precisa
  1. Ridgid R82005  2 Speed Gear Train  Replacement, Housing Assembly: passo 1, imagem 1 %32
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005  2 Speed Gear Train  Replacement: passo 2, imagem 1 %32
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005  2 Speed Gear Train  Replacement: passo 3, imagem 1 %32 Ridgid R82005  2 Speed Gear Train  Replacement: passo 3, imagem 2 %32
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005  2 Speed Gear Train  Replacement: passo 4, imagem 1 %32 Ridgid R82005  2 Speed Gear Train  Replacement: passo 4, imagem 2 %32
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005  2 Speed Gear Train  Replacement, 2 Speed Gear Train: passo 5, imagem 1 %32 Ridgid R82005  2 Speed Gear Train  Replacement, 2 Speed Gear Train: passo 5, imagem 2 %32
    • Remove the 2 speed gear selector by carefully lifting it out of the housing, making sure it is free from the speed switch rail.
    • The 2 speed gear selector may fall out on its own.
    • When reassembling, make sure all drill components fit properly in the grooves of the Housing Assembly.
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S1-G2, Leahy Spring 2019 Membro de USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Duração total: 530
