Ir para o conteúdo principal
Ridgid JobMax R2851 Series B Motor Replacement
O que você precisa
  1. Ridgid JobMax R2851 Series B Motor Replacement, Motor: passo 1, imagem 1 %32 Ridgid JobMax R2851 Series B Motor Replacement, Motor: passo 1, imagem 2 %32
    • Unplug the device from the wall.
    • Orient the device so that the trigger is facing downwards.
    • Place your thumb and index finger on the two buttons located on the head of the tool.
    • Press the two buttons in and pull the head of the tool off.
  2. Ridgid JobMax R2851 Series B Motor Replacement: passo 2, imagem 1 %32
    • Loosen all eight 15mm T10 Torx screws.
    • You do not need to fully remove the screws yet; just loosen them enough that the device shell starts to open.
  3. Ridgid JobMax R2851 Series B Motor Replacement: passo 3, imagem 1 %32
    • Orient the device so that the cord end is facing upwards.
    • Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
    • Make a shallow cut to avoid damaging internal hardware.
  4. Ridgid JobMax R2851 Series B Motor Replacement: passo 4, imagem 1 %32 Ridgid JobMax R2851 Series B Motor Replacement: passo 4, imagem 2 %32
    • Completely remove all eight 15mm T10 Torx screws.
  5. Ridgid JobMax R2851 Series B Motor Replacement: passo 5, imagem 1 %32 Ridgid JobMax R2851 Series B Motor Replacement: passo 5, imagem 2 %32 Ridgid JobMax R2851 Series B Motor Replacement: passo 5, imagem 3 %32
    • Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
    • Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
    • Watch out for the locking mechanism for the head of the device when removing.
  6. Ridgid JobMax R2851 Series B Motor Replacement: passo 6, imagem 1 %32 Ridgid JobMax R2851 Series B Motor Replacement: passo 6, imagem 2 %32
    • Grip each of the sides of the two green circuit boards and slide them up.
    • Grip each side of the device trigger, and slide it up.
    • You do not need to completely remove these parts. Sliding them upward provides the needed room.
  7. Ridgid JobMax R2851 Series B Motor Replacement: passo 7, imagem 1 %32 Ridgid JobMax R2851 Series B Motor Replacement: passo 7, imagem 2 %32
    • Grip the motor firmly and pull towards the back of the tool, rotating back forth until the motor is free.
    • When reinstalling the motor, use a spudger to pull back the brushes. This allows the motor to slide into place.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 698
