Introdução
This guide shows you how to replace the base assembly on this circular saw. This part may need replacement if it is damaged, broken, or warped in such a way as to prevent making clean cuts. Symptoms of a warped base assembly include: cuts skewing to the side when the blade is set at zero degrees or a binding blade caused by the cutting base not sitting flush against the cutting surface.
O que você precisa
Remove the supplied Allen wrench from it's nesting space in the front of the handle.
Depress and hold the spindle lock button located between the handle and blade shroud.
Using the supplied 6mm Allen Wrench, unscrew the bolt securing the blade and remove the blade.
