Ir para o conteúdo principal
Ridgid GEN5X R8653 Base Assembly Replacement
O que você precisa
  1. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: passo 1, imagem 1 %32 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: passo 1, imagem 2 %32 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: passo 1, imagem 3 %32
    • Always disconnect battery and use gloves when working with the saw blade. Failure to do so may result in damage or injury!
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • Depress and hold the spindle lock button located between the handle and blade shroud.
    • Using the supplied 6mm Allen Wrench, unscrew the bolt securing the blade and remove the blade.
  2. Ridgid GEN5X R8653 Base Assembly Replacement: passo 2, imagem 1 %32 Ridgid GEN5X R8653 Base Assembly Replacement: passo 2, imagem 2 %32 Ridgid GEN5X R8653 Base Assembly Replacement: passo 2, imagem 3 %32
    • Remove seven 6mm T20 Torx screws located around base of saw.
    • Pull base assembly away from saw.
    • These screws are very tight and need significant force to be removed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 222
