Introdução
Is the trigger of your drill not engaging the chuck when pressed? If so, here is a guide that provides a solution with a change of the trigger. You need a plastic opening tool, a Torx T15 screwdriver, and a Torx T10 screwdriver to remove the requisite components.
O que você precisa
Orient the drill to have the side with the screws facing up.
Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
Use a plastic opening tool to gently pry the trigger from the brown connector.
