Ir para o conteúdo principal
Ridgid GEN5X R8611506 Outer Case Replacement
O que você precisa
  1. Ridgid GEN5X R8611506 Outer Case Replacement, Outer Case: passo 1, imagem 1 %32 Ridgid GEN5X R8611506 Outer Case Replacement, Outer Case: passo 1, imagem 2 %32
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Outer Case Replacement: passo 2, imagem 1 %32 Ridgid GEN5X R8611506 Outer Case Replacement: passo 2, imagem 2 %32 Ridgid GEN5X R8611506 Outer Case Replacement: passo 2, imagem 3 %32
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Outer Case Replacement: passo 3, imagem 1 %32 Ridgid GEN5X R8611506 Outer Case Replacement: passo 3, imagem 2 %32
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Outer Case Replacement: passo 4, imagem 1 %32 Ridgid GEN5X R8611506 Outer Case Replacement: passo 4, imagem 2 %32
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 233
