Introdução
Is your light not working when the light switch is pressed? If so, here is a guide to fix the light switch. You will need a plastic opening tool, a Torx T10 screwdriver, and a Torx T15 screwdriver to remove the requisite components.
O que você precisa
Orient the drill to have the side with the screws facing up.
Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
Locate the light switch near the bottom of the drill's inner components.
Gently remove the light switch from the casing.
