Introdução
If the selector switch of your drill is stuck or not switching the chuck's direction when pressed, use this guide to remove and replace your selector switch.
O que você precisa
Orient the drill to have the side with the screws facing up.
Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
Gently lift the trigger up.
Unhook the selector switch from the trigger.
Remove the selector switch.
Quase terminado!
Conclusão
