Ir para o conteúdo principal
Ridgid Angle Grinder R10202 Power Trigger Replacement
O que você precisa
  1. Ridgid Angle Grinder R10202 Power Trigger Replacement, Ridgid Angle Grinder R10202 Handle Disassembly: passo 1, imagem 1 %32 Ridgid Angle Grinder R10202 Power Trigger Replacement, Ridgid Angle Grinder R10202 Handle Disassembly: passo 1, imagem 2 %32 Ridgid Angle Grinder R10202 Power Trigger Replacement, Ridgid Angle Grinder R10202 Handle Disassembly: passo 1, imagem 3 %32
    • Using a Torx T20 screwdriver, unscrew the five M5 x 16 mm screws.
    • Using the T20 screwdriver, remove the M5 x 28 mm screw.
  2. Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 2, imagem 1 %32
    • Using a Torx T10 screwdriver, remove the M3 x 10mm screw.
  3. Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 3, imagem 1 %32 Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 3, imagem 2 %32
    • Gently pull off the right side handle.
  4. Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 4, imagem 1 %32 Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 4, imagem 2 %32 Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 4, imagem 3 %32
    • Using a hex head screwdriver, remove the two 8-16 x 1/2in screws.
  5. Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 5, imagem 1 %32
    • Gently pull away the bend relief.
  6. Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 6, imagem 1 %32 Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 6, imagem 2 %32
    • Remove the one M4 x 14 mm screw using a Phillips screwdriver.
  7. Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 7, imagem 1 %32
    • Gently lift away the switch and wires.
  8. Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 8, imagem 1 %32 Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 8, imagem 2 %32
    • Press down the handle lock button.
    • Force-ably twist and pull away the left side handle assembly.
  9. Ridgid Angle Grinder R10202 Power Trigger Replacement, Power Trigger: passo 9, imagem 1 %32 Ridgid Angle Grinder R10202 Power Trigger Replacement, Power Trigger: passo 9, imagem 2 %32 Ridgid Angle Grinder R10202 Power Trigger Replacement, Power Trigger: passo 9, imagem 3 %32
    • Using a bit driver, carefully remove the 4 M3.5 X 7mm holding the wires on.
    • Remember the order and position of each wire.
  10. Ridgid Angle Grinder R10202 Power Trigger Replacement: passo 10, imagem 1 %32
    • The Switch is now free of the Grinder. Dispose of the broken Switch and install your new Switch.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 438
