Ir para o conteúdo principal
Ridgid Angle Grinder R10202 Disk Guard Spring Replacement
O que você precisa
  1. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement, Disk Guard Spring: passo 1, imagem 1 %32
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  2. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 2, imagem 1 %32 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 2, imagem 2 %32
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  3. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 3, imagem 1 %32 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 3, imagem 2 %32
    • Unscrew the 5 M5 X 10mm screws using a Torx T20 Bit.
    • Carefully separate the spacer from the guard.
  4. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 4, imagem 1 %32 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: passo 4, imagem 2 %32
    • Gently push the spring away from the spacer.
    • The spacer, spring, and guard lever should now be all separate.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 823
