Ir para o conteúdo principal
Ricoh Super 8 800z Eyepiece Adjuster Replacement
O que você precisa
  1. Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: passo 1, imagem 1 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: passo 1, imagem 2 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: passo 1, imagem 3 %32
    • Remove the rubber covering from the eyepiece by slowly pulling down on the cover from any direction.
  2. Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 2, imagem 1 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 2, imagem 2 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 2, imagem 3 %32
    • Use Phillips #000 screwdriver to remove the three screws around the eyepiece lens.
    • Remove the metal plate from the eyepiece.
  3. Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 3, imagem 1 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 3, imagem 2 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 3, imagem 3 %32
    • Turn the adjustment ring counter clockwise until it is as close to the lens as it will go.
  4. Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 4, imagem 1 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 4, imagem 2 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 4, imagem 3 %32
    • Remove the screw on top of the back panel of the camera using a Phillips #000 screwdriver.
    • Use a plastic opening tool to lift the plastic covering to reveal a screw underneath it.
  5. Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 5, imagem 1 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 5, imagem 2 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 5, imagem 3 %32
    • Continue to hold the plastic covering back with the plastic opening tool.
    • Use a #1 flathead screwdriver to remove screw in the oval opening beside the eyepiece. Be careful not to drop the screw into the camera body.
  6. Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 6, imagem 1 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 6, imagem 2 %32 Ricoh Super 8 800z Eyepiece Adjuster Replacement: passo 6, imagem 3 %32
    • Slide the eyepiece adjuster out of the camera body.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 421
