Ir para o conteúdo principal
Ricoh Shotmaster 130Z Zooming Lens Replacement
O que você precisa
  1. Ricoh Shotmaster 130Z Zooming Lens Replacement, Zooming Lens: passo 1, imagem 1 %32
    • Set the dials to "A" (Auto), and Off mode.
    • You will not be able to move these dials once the case has been opened.
  2. Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 2, imagem 1 %32 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 2, imagem 2 %32 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 2, imagem 3 %32
    • Remove the 5 Phillips screws from the sides and the back.
  3. Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 3, imagem 1 %32 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 3, imagem 2 %32
    • Remove the 5mm JIS #00 screws from the bottom of the camera.
    • Pay attention to the 6mm screws on the sides of the tripod slot, as they are a slightly different size from the rest of the screws. However, you still may use a J00 screwdriver to remove them.
  4. Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 4, imagem 1 %32 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 4, imagem 2 %32
    • Using an opening tool, lift the case of the tripod slot (on the bottom) until the back portion of the case is released.
    • Continue to use the the opening tool to insert it and lift right next to the strap of the camera.
    • This will release the front portion of the case.
  5. Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 5, imagem 1 %32 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 5, imagem 2 %32 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 5, imagem 3 %32
    • Use a JIS #0 screwdriver to remove the three marked screws found around the perimeter of the lens.
  6. Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 6, imagem 1 %32 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 6, imagem 2 %32 Ricoh Shotmaster 130Z Zooming Lens Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Proceed to remove the two screws using a JIS #00 screwdriver.
    • Use tweezers to lift the lens off of the board.
Conclusão
Equipe
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G4
3 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 596
