O que você precisa
Place curling iron on a flat surface along with the required tools and swivel cord replacement.
Ferramenta utilizada nesse passo:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Unscrew the two 3mm screws from both sides of the barrel clip with a 3.0 flathead screwdriver to remove the clip from the barrel.
Set the two screws and barrel clip aside for reassembly at a later point.
