Ir para o conteúdo principal
Revlon One-Step Hair Dryer Barrel Replacement
O que você precisa
  1. Revlon One-Step Hair Dryer Barrel Replacement, Barrel: passo 1, imagem 1 %32
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Barrel Replacement: passo 2, imagem 1 %32 Revlon One-Step Hair Dryer Barrel Replacement: passo 2, imagem 2 %32 Revlon One-Step Hair Dryer Barrel Replacement: passo 2, imagem 3 %32
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Barrel Replacement: passo 3, imagem 1 %32 Revlon One-Step Hair Dryer Barrel Replacement: passo 3, imagem 2 %32 Revlon One-Step Hair Dryer Barrel Replacement: passo 3, imagem 3 %32
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 37
Duração total: 1,380
