Introdução
If your hair dryer is not blowing out hot air, has a restricted air flow, or is producing a burnt smell, the air inlet may be defective. The air inlet is a vital source of the hair dryer as it protects the mesh filter from any further debris or damage. As a result, this guide will teach users how to properly replace this component of the Revlon One-Step Hair Dryer.
O que você precisa
First, remove the pink panels on each side of the handle in order to access the screws.
Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
Next with your free hand carefully pull the cord out of the port of the dryer handle.
Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
Once the lint filter is detached from the plastic filter protector, you can now replace it.
Uma outra pessoa concluiu este guia.
