Ir para o conteúdo principal
Revlon 473 Thermal Cutout Replacement
O que você precisa
  1. Revlon 473 Thermal Cutout Replacement, Shell: passo 1, imagem 1 %32
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Thermal Cutout Replacement: passo 2, imagem 1 %32
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Thermal Cutout Replacement: passo 3, imagem 1 %32 Revlon 473 Thermal Cutout Replacement: passo 3, imagem 2 %32 Revlon 473 Thermal Cutout Replacement: passo 3, imagem 3 %32
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Thermal Cutout Replacement, Thermal Cutout: passo 4, imagem 1 %32
    • Locate the thermal cutout under the coils of the heating element.
  5. Revlon 473 Thermal Cutout Replacement: passo 5, imagem 1 %32
    • Test the thermal cutout for continuity using the multimeter.
    • Make sure the multimeter is set to 200 ACV and bring the probes toward the thermal cutout.
    • If the numbers on the multimeter continue to change, the circuit is closed and properly functioning.
    • If the multimeter reads a consistent number, the circuit is opened and the thermal cutout needs to be replaced.
  6. Revlon 473 Thermal Cutout Replacement: passo 6, imagem 1 %32
    • To replace the thermal cutout, use the spudgers to extract the object.
    • To remove, wedge it back and forth until it comes free.
    • You do not need to take out the gold piece, only the thermal cutout.
  7. Revlon 473 Thermal Cutout Replacement: passo 7, imagem 1 %32
    • Replace the old thermal cutout with a new thermal cutout by snapping it into place.
Conclusão
Jessica Leyva
Membro desde: 09/18/12
143 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 1-5, Propen Fall 2012 Membro de Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 1,886
